Speedo jumping, fuel gauge erratic
My speedo started bouncing around on saturday, then the fuel gauge started going up and down round corners, i have been told it could be the vehicle speed sensor, i took a sensor off the gearbox (towards the back of the gearbox by the bulkhead, it unscrewed and it has a pin/spline inside the sensor that turns.
The only numbers on the part i could see where these ones:
I have tired looking on ebay for vehicle speed sensor but the parts look nothing like this one, is it the right thing and does anyone know the part number for a new one ???
The car is a polo 6N2 GTI (2000 W reg)
Edited by naf536
  • Views 1.4k
It may not be the fault!!
It could be an earth wire which is located near the thermostat housing, its got two wires going into it and its actuallu screwed in with the housing if i can remember correctly, i had the same problem; the wire was loose.
I hope this helps and it saves you alot of time and money!
BTW this should be in the Technical Section of the forum.
Ussy
