does anybody else's polo......
..steam up real bad and not like going into reverse??
  • Replies 11
  • Views 1.6k
mine didnt like going into reverse but turned out to be the gear selector needed replaced, about £32 from VW new
doesnt steam up
You may have a small water leak causing condensation?
renew your pollen filter...
Aye mine steams up, i think its cos my stupid open air roof is leaking. Takes a while to demist as well so i think a new pollen filter is needed.
how do you change the filter where is it? is a 6N2 the same?
Mine has never steamed up bad and clears any slight mist easy so can't comment on that. The reverse issue though. I'm assuming its crunching your on about not general finding and selecting the gear.
They do like reverse if you do it right.
First make sure the car is stationary
Select first
Select neutral
Release clutch fully
Depress clutch
Select reverse and it should go in a dream.
mine doesnt like reverse either, takes a number of attempts to get it in...sometimes does it with 1st aswell.
as for steaming up, mine only does that cause i left my passenger window down all night last week, so the insides really damp.
Select first
Select neutral
Depress clutch
My valver does both but i have a pollen filter to fit. just haven't had time.
But i have got used to it and you can work around it like kwijibo_coupe said. You can do it that way or i have noticed that if you select reverse then release the clutch slightly then select reverse again whilst the clutch is very slightly rasied it slots in very easily then you are off. :)
Kuszpit :)
The reverse question....... press your clutch in, wait 2-3 seconds then engage reverse gear, shouldnt crunch, if it doesnt then your selecter cable needs adjusting or renewing
cheers lads, it goes in just not so easy sometimes.
wheres the pollen filter?
In the scuttle, under the plastic cover on the passenger side :)
