Internal Weather
My Polo seems to be getting a bit moist during these winter months, in fact it's not rare to see a puddle in the footwells (drivers side more often). As well as that, I'm finding that the inside of the windscreen is holding a lot of water / condesation and my seats / steering wheel is damp... Any ideas please people?
  • Replies 9
  • Views 1.4k
sounds like your battery tray has rotten through
I shall have a look tomorrow, any more ideas though? Last time I was in the bay all seemed well :).
you need to look up from under the drivers footwell with a torch as it rots behind the bracket which positions the battery. also check around the windscreen rubber, if a chip has rotted through it will let water in. had this happen on a mk3. the battery tray was also rotton! was well miffed when i welded up the battery tray only to find the car was still leaking!
Can I just ask, Isn't the battery tray on the roght hand side of the car (Passenger side) why would this cause water to come into the drivers side? I only ask this as I am trying to find the cause of my water leak too!
Should be on the driver's side in a Mk3..
:lol:
Sorry my ba thought he was talking about a MK4
Ooops :cry:
Lift your battery out and have a look.
There's also a drain hole between the battery tray and the inner wing, this can get blocked by leaves and crap making it overflow down the heater hole.
As g40jpn says, window frames can also rot, but it's not hugely common on mk3's, you'll normally see some bubbling coming out from under the rubber.
Incontinence problem?
On a serious note, sounds like your battery tray is rotten and, as suggested above, window seals may be leaking.
I'll have a look tomorrow morning guys, cheers for the help. Will let you know how it gets on (if I get outta bed...).
