Mk 3 Leak :(
I've got a leak in my boot.. It's pretty bad (I could probably take a bath in the boot after a day of hard rain lol..) But I'm pretty sure it's the seal is just messed up and I need a new one.
So I went down to VW and they quoted me 60 quid for it!!!!
So I thought screw that.. However, can't seem to find the right part on the net anywhere.. Theres quite a few rubber seals but none of them are polo or even vw specific.
So anyone know somewhere I can pick the seal up? And for a better deal than VW if possible..
Cheers.
Edited by Hatti
  • Views 845
you wont find a specific polo one elsewhere
if you google "universal rubber seal " and so on you can find similar ones for about £5 a meter , so measure up and see if anything matches
has the seal got a tear in it? its often the lamps that leak
No tear it's just all crumbly..
Is there something I can tighten up on the lamps to see if that stops it? Or I've heard it could likely be behind the bumper as well..
id remove each lamp and look at the gasket ...you will prob see a dirty trail of water /muck if its leaking there
clean em up and refit ...then trickle a hose or watering can over each area and look in the boot for where its coming in
the bumper fixings should have a little gasket thing ...again remove and have a look
you will be there forever trying to guess where its coming...only way it to watch it , could get a mate in the boot with a torch while you hose it
