Do smaller wheels make the Speedo wrong?
Best way to check is use a gps/ satnav which will give you a more correct reading with your dash.
Kuszpit :)
Great idea ;) just have a gps or satnav as a speedo instead lol
Is there any way to change/modify a speedo cos i know it will have got harder with all these electronics they have in cars these days but speedo's are different on different cars so could you maybe put a mini speedo in a polo with undersized wheels on? (just a thought)
  • Replies 31
  • Views 4k
sorry didnt notice the wheel diameter .
wasnt thinking about stretch either with that.
i blame 4am starts.
Haha had me worried then, went and checked calcs and the lot :lol:
Kuszpit :)
Could just make your own clock inserts to suit... theres a how-to somewhere on here
A dial speedo is never going to be 100% accurate no matter how hard you try.
The reading won't only differ due to wheel size but also your seating position, the speedo sensor in the gearbox and the resistance of all the gismo's inside the speedo unit.
In my mk4 I cracked open the clocks and moved the needle slightly down as I did quite a heavy rolling radius reduction but this only changes the speed shown. The miles on the electronic unit still go up at the same rate.
To be honest I wouldn't worry too much about it.
yeah i'm not that worried i'm just gettin things straight before i do get a car :) and lower it of course ;)
this is what sort of sparked this question off ->
Bottom of this page tells you speed differences with wheel widths and stuff.
Edit: helps if you put the link up... Click me!
Edited by stefduff
