jobs that need help on :)
right. In my polo i have standard windows with the crappy spinny thing on to open the windows(cant for the life of me think what they are called atm) well i was wondering, how hard would it be to put electric windows in a car which does not already have them and how much would you be looking at. cheers :)
  • Views 860
What car, year, are you at all competent?
sorry its 1996 n reg polo.
96 n reg, 90 spec electrics, It's relatively straight forward.
All you need to do is get a doner car in a scrappy, get the window mech's out, the door wiring looms and the bit that runs between the back of the dash, fuse box and the switches.
Whilst you're at it you may as well lift the central locking out as well and fit that.
Wiring them in is also really really easy, they're all colour coded and as long as you have a mini bit of intellect it's very do-able yourself.
o rite cheers mate really appriciated :)
It's easy, all you have to do is think about it.
Look for a red vr6 6n on vortex and there's a fuse box diagram that also shows you were all the plugs go on the back and if you get all the wirin out of the donor car I think you can plug and play!
(I did abit of research awhile back and this is the conclusion I came to and then I decided I prefered the windy mechs as the electric ones are known to have problems and I basically couldn't be arsed lol! It's an easy enough job just very time consuming!)
edit: found it for you, scroll down and theres a key and a diagram!
http://forums.vwvortex.com/zerothread?id=4193518&page=2
Edited by Pepe
