windscreen removal / refitting
I have a 1986 MK2 squareback which had a small stone chip in the bottom middle of the screen on monday, by tuesday it was a 6 inch crack and yesterday going to college i was watching it grow from the middle of the windscreen all the way to the passengers side edge.
has anyone had any success removing and fitting a new windscreen, if so how?
to remove you push the rubber over the metal lip on the bodywork , usualy with a large flat screw driver.....or you can lay back and heave it out with your boots
to refit ...fit the rubber onto the new screen and run some 4-5mm cord in the slot where the lip goes , spray lots of soapy water arounf the rubber and place the screen onto the car with the cord ends inside
get someone to apply gentle pressure to the outside while you sit inside and pull the string , when you get it right the rubber will pop over the lip as you yank the cord , once its done all the way around gently thump the seal with the base of your fist to seat it
having said all that...its fairly easy to crack a new screen take it slow and lots of soapy water
I knew it was done like that fot rear side windows as i found a how to on a golf forum but didnt know it was like that for a windscreen... thanks for your help.
i will let you know how i get on :?
yep just the same idea as side windows...but side glass is alot harder to break
Use a screewash solution to lubricate the seal as you put it in.
Also, I know it's not easy at thiks time of year, but try and do it somewhere warm, or at least warm the seal up in the house overnight.
