cd player wiring HELP!
Alright, I've got slight problem with my cd player is has all the wires coming out of the cd player with the black brick thing on the end the only problem is my car wiring does not have the brick on to just clip straight into place could somebody tell me what I need and maybe if your good ;) how to do it cheers
Edited by jbird2009
  • Replies 10
  • Views 1.4k
i take it then you have bare wires in the dash if so
post up what colours you have and i will tell you which is which
is there nothing i could buy to attach to something so i can plug the brick in? and theres:
red
brown
red/brown
blue/white (i think)
blue/brown
not really 100% sure but ill get a picture and post it up for you tomorrow. is there any info you could give me now?
no body able to help me ??
you need to get a male iso plug 9available from any car audio shop
your wiring is as follows
red = 12v+ connect to the yellow of the h/u
brown = earth connect to the black of the h/u
brown/red not needed
blue/white should actually be blue/grey = illumination connect to the orange of the h/u
blue/brown will be a speaker negative but you should have 3 more wires for these
you will need to run an ignition live from either the thick red/black on the heater switch or from the black wire on the rear of the fuse box
this will need to connect to the red wire in the stereo iso plug
[/quo
what kind of wire do i use to connect from the heater switch to the red wire on the h/u
guessing you have the same problem then cleggie? and are the iso plugs for a 1996 polo? if so mate who you selling them for? cheers
what do you mean mate selling what haha
just get some cable rated at 8.75 amps from a car accessory shop
was talking to TROUBLESTARTER mate haha.
o ok haha an cheers
