FAILED M.O.T just on emissions
had the car in for its MOT. failed on emissions as stated
car - 1.4 16v 6n
question? - how do i lower the emissions
i warmed up the engine before taking it in i put sum petrol lean stuff in that didnt help.... i changed the spark plugs and airfilter..... not helped
am i right in thinking it could be the lambda sensor? or the Cat convertor if so how much money are we talking to sort them two out ???
all advice i am thankful for in advance..
  • Views 1.8k
Did you try this http://www.halfords.com/webapp/wcs/stores/...tegoryId_165750
I have heard it is really good, when you put it in you have to do a fair few miles before it actually helps to clean the gunk out of the engine! When you put your petrol / engine cleaner in, did you make sure it had been in for at least 3 days?
Hope this helps :)
id try lambda first its only about 60 quid tops i think for one
id pin it on the lambda sensor, my GT failed on emissions on thursday so me and a mate leaned the afm right out to make it pass, new sensor is on order now ;)
How much has it failed by? Alot?
Mine failed on its emissions on my last MOT, I just put a full bottle of petrol magic in, a fivers worth of BP ultimate, kicked it's head and it passed - Just!
Lambda sensors are quite dear like. I've looked on ECP and for a Bosch one you're looking at £70.
have u got the emissions print off if soo tell me you are readings and i can help u out
I managed to get hold of a lamba sensor off here for £15 posted. It might not be that though, mine passed the emissions not long ago, but it still needs a lambda sensor...
alright everyone thank you for the replys !!!
the reading off the sheet was .....
Engine Speed: 2500 to 3000rpm
CO: 0.61 FAIL
HC: 153 PASS
other one : 1.030 FAIL
any help?
failed on
001 exhaust emissions carbon monoxide content after 2nd fast idle
002 exhaust emissions Lambda reading after 2nd fast idle outside specified
