mk1 1.3 engine!
Ok peeps, need room in my garage and bit of cash for my derby rebuild!
I have the 1.3 engine i have taken out of my 1981 derby! Just befor i took it off the road i put all new plugs, distributer cap, roter arm, points and condenser all from vw! Run like a dream! Done about 30,000 miles! Comes with 4 speed gearbox! Thinking £70, will be willing to split!
ENGINE HAS BEEN DRAINED OF OIL!
Collection only from croydon area!
PICS ADDED ON POST BELOW!!!!!!!
ITEMS SOLD:
CENTER BOX + BACK BOX (ASHLIE SYSTEM)
CARB FROM EXZOMBIE ENGINE
DIZZY CAP. ROTOR ARM, POINTS AND CONDENSOR FROM DERBY ENGINE
EXZOMBIE ENGINE
MK1 EXHAUST HEAT SHIELD
4 BRANCH MANIFOLD
MK1 EXHUAST MANIFOLD + DOWN PIPE
ITEM PROVISIONLY SOLD:
5 SPEED BOX
STILL FOR SALE:
1.3 BLOCK FROM MK1 DERBY
4 SPEED BOX FROM DERBY
AND MIDDLE BOX AND BACK BPX FROM THE MK1 DERBY!!!
Edited by monkeypolo
  • Replies 30
  • Views 1.2k
hi mate do you have the manifold for the mk2 1 is the the one with two pipes cominmg out pm me mate
Pm'd buddy
mk1 derby engine, does it have a manual choke? if so how does £55 collected?
Edited by higgo
hi mate i want a 1.3 engine, will a mk2 fit in my mk3 coupe (mk2 facelift) oh and can you clear this up 4 me? is my coupe a mk3 or mk2 if its the facelift? ta in advance
The engine will bolt in fine mate but as yours is a facelift means you prob got an ecu for your original engine er i dunno if your car is mk2 or mk3 tbh
I have 1.3 engine with carb that came out my my coupes (exzombie) cant remember full spec on the engine but is all listed in the mk2 thread! Has sat for while but was working spot on whilst car was driving! Done about 120 miles iirc correctly! (NO GEARBOX WITH THIS ENGINE!) thinking about £50
I also have the 1.3 engine i have taken out of my 1981 derby! Just befor i took it off the road and out i put all new plugs, distributer cap, roter arm, points and condenser all from vw! Run like a dream! Done about 30,000 miles! Comes with 4 speed gearbox! Thinking £70, will be willing to split!
BOTH ENGINES HAVE BEEN DRAINED OF OIL!
can you give me an idea of the actual spec of the mk2 lump? realy interested dependant on that
Hay dude sure engine is a 2g block was running a gk inlet ported and polished with weber 32/34 dtmr carb but that been sold so now just the BLOCK.
PICTURES!!!!!!
MK1 down pipe scrape damage!!!
(MORE PICS TO COME OF REST THE SYSTEM!)
WILL TAKE THE EXHAUST MANIFOLD OFF THE ENGINE IF WANTED!!!
MK1 engine +gear box pic's!!!
4Speed Gearbox pic!!
whats the gearbox code for the 5 speed? looking to fit my mk2 golf and how much of course
dude!!!! i need a 5 speed box to get my GT lump in my car finaly! PM me your number dude and we can chat about it!
Baxterr pm'd
I will get the code for both box's tomoz hopefully! Thinking £50 each!
Have you got a coil and amp (little black box) and a dizzy?? Desperately needed! Also need a gearbox mount (for a gt box??) and the little ball and cage the gear selector goes in? Cheers
ooh please pm cause wrong email on here so will forget to check it! ;)
Thanks mate
hi pal is that £60 for the center section and back delivered?
if so ill take it
gaz
if so ill take it
gaz
Hay dude i guessing you mean posted right lol? Er i can do it £65 posted cos going got me abit to send them both! Sound good?
If the manifold ain't sold message me please
if you break can I have the gearbox mount please
cheers
sorry dude i already got a buyer just waiting for payment!
cheers
you can def have it i got a couple laying around! £15 posted??
cheers
You got another 5 speed gearbox mount lying around? If you do send me a PM and i can pay immediately.
I had look this morning dude, sorry i havnt got a 5speed box mount it was a 4 speed mount which i gave away and forgot i did! sorry fella!
POST HAS BEEN EDITED AND CLEANED UP OF UNNESSASERY POST'S BY ME!
Cheers anyway fella.
cheers
Pm'ed cheers
melon
Exzombie engine PROVISIONLY SOLD (pending pivking up this week end!!!)
BUMP!!!! Going on hols tomoz so be back in week!!!
Here are some pics of the mk1 exhaust system!!!
PICS:
With the back box i sanded it right back to bare metal ant sprayed it with heat proof black paint!! got bit rust on the join but should be fine as didnt blow when i had it on the car!
MK1 EXHAUST MANIFOLD + DOWN PIPE SOLD PENDING PAYMENT!!!
