Going to look at a M5 Polo Gti
Hi, I'm going to look at a Polo Gti this weekend. 2000model.
88k.
The owner tells me has had the clutch and gearbox replaced. So obviously ill ask for proof.
Whats there to look out for on them?
Do they rust anywhere ( I no its only a 9yr old car )
I'm aware of the slow/sticky window motors..
The car is standard btw.
  • Replies 32
  • Views 2.6k
88k.
-Climate control if its got it
-light washers
thats all i know of, then just general like brake discs etc
Light washers, so when i press for windscreen wash, they should open and spray the headlights?
think the lights have to be on but yeh thats the idea, i think.
Kuszpit :)
They only work when you've got a certain amount of washer fluid in I think! I thought mine wern't working but i just topped it up and they worked again. Correct me if I'm wrong though!
They wont rust - they are galvanised :thumbsup:
yeah, no rust lol. Oh the joys
washers come on with lights on and bottle has to be near full.
Check pedal box recall has been done. Should be a sticker in the boot.
Drive it, look for whines or knocks. Engine whines could indicate a cambelt tensioner on its way out.
wheels will be corroded. But they all are.
If the pedal box recall hasnt been done, i take it i just have to go to Vw and request they do? Any more info on this..
Has to be broken now before VW will do it for free.
just get someone with a heavy foot
Pedal box went on my 6n, didn't realise its on the 6n2's aswell! cost me £250 =/
Its just a inconvinience if it goes
Its only a GTi which is free...others charge.
Depends on the dealer aswell. Volkswagen say its free. Its upto the dealers discression for them to do it for free. Its a good 3 hour job.
Neil were abouts in the boot do they put this 'pedal box done' sticker?!?!?
next to the one with all the paint code, vin number and optional extra codes on.
Dont worry if yours hasnt been done..mine hasnt either lol
EDIT - You'll find that sticker under the carpet near the spare wheel
Edited by neil_dubgt
If there is rust anywhere, walk away, simples.
Even though he says he has had the 'box done, still give it a good test.
Try every gear at a good rpm and listen for any whines at all.
And also at 88k, has the cambelt ever been changed? I think they are a 60k or 90k interval.
every 60k or 4 years my friend :)
Unless theres a bit of the paint that's chipped off 8-)
That's good advice on uk-polos.net. Couple of other things....
The car should be able to pull in 5th from 30mph...if not then likely the wrong gearbox has been fitted, take it up to 60-70mph in 5th as you may also experience a flat spot, this will likely mean the throttle body needs to be cleaned (DIY job or £80 at VW)
Check the rear wash, common problem, not difficult to fix but might help knock a few quid off
Try and get the car on a ramp and check for any oil leak around the gear selector rod, common problem and not an expensive fix (£80 at VW) but I doubt the gearbox will last long with one
good luck
There galvanised so wont rust.
unless the galvanised coating has chipped off
Or the boot handle, mine has bubbled up. I guess a normal one doesn't differ from a GTI?
It's not like a wood varnish?.Galvanizing is an accurate and very hard protection for mild steel and alloys.Not as tough as stainless but the next best thing,applying a Zinc liquid to the steel at extremely high temperatures.When steel or an alloy is galvanised it can be welded,machined and bent etc without damaging the coating.Not like applying a coating as such so Galvanising shouldn't chip off at all.
Brad
pretty much nailed it there bradders
