need some help ?
hey not been on for a while some of you may rember me did have a mk2 polo comet blue b424 yat i think i no I'm not that popular on the forum as i did runin some cars by driveing like a dick and i just want to put it in the clear i had relised what happens etc. and i have calmed and matured now on the roads! so please no arguments
now I've had a few cars and by far the mk2 polo was my fav and i miss it alot wish i never sold it found a mk2 breadvan near me just wonderd what i should look for as in rust or common faults any help would be great thanks alot nath
  • Views 734
bump any one kinda going up tomoz to look at it
That plate sounds familiar to me. Usually the main fault (that I know of anyway) especially in this weather is with the carb. So it might run rough or cut out when its cold. So make sure they haven't had the engine running before you get there to try and hide this problem. Rust wise the normal places for an old car, sills, front and rear valances, bottoms of doors and wheel arches. Petrol tanks can leak at the filler neck as well as mud and shite in general seems to sit in there. Check under the spare wheel well also cause they can sometimes get a bit of a hole in them there. I've had a few with holes there but only small, but I've viewed a car once that had a hole big enough to put your hand through :lol:
Oh and if its got a sunroof check that doesn't leak either. errrrmmm... and check the battery tray as they can rot away to.
thanks for the reply heartagram il check that then and yeah it was phil js old one i brought it off him and sold it on to some one on the fourm wich wasnt happy with it as ther was alot of things wrong with it but as u can tell i dont no much about them
