Front camber
Is there anyway to get front camber on my mk4 polo on lowering springs, I have seen it done on some polos and lupos but not sure how, i can only find rear camber shims too?
  • Views 1.2k
camber bolts :-D
camber bolts :-D
Shims.
can you not undo the suspension from the hub and tilt the hub, till you got what you want and then tighten back up??
Thanks sam ill buy some of those bolts :)
as clarkson20 said, on the front you can loosen the two bolts that hold the leg to the hub, set to desired camber and then tighten up again. Its only if this adjustment still won't give you the desired camber that you have to buy the different bolts and stuff as the others have said.
would it be hard to get the same camber each side though?
