92 Polo GT with 1.6 GT engine breaking
Sadly i'm going to have to break my Polo GT due to it failing on underside rot and fair few other things. I dont have the time to fix it so its getting sold for parts :-(
Bits worth selling are:
Bigger master cylinder, iirc its a 16v Golf item
G40 brake calipers
Front lower strut brace
GT badges (front and rear)
Black GT interior (Very good condition)
Remote central locking (Black Hawk from Ebay, very good kit)
GT inlet manifold which has been paired (welded) with the flanges from an ABU manifold so it fits the 1.6 AEE/ABU/AEA block. This was done by a local engineering company and i havn't had any problems with it over the 10k + miles i have covered. Id rather sell it with all the GT running gear and the engine as i dont have much space. The engine is paired to a CL 5 speed gearbox which is ok but crunches under full throttle in 2nd and can be a bit whiney.
As far as the engine setup goes i have been doing 50 miles a day and it has been great, on the A roads at 60mph and having to overtake lorries frequently it still does around 95 miles to £10 of fuel. Its a great setup and has kept me happy for quite a while, its certainly a fun drive.
However the engine has some minor leaks, rocker cover and the sump bolt so nothing major but as with most of the 1.6's the valve stem seals weap so if you leave it for a few days it might smoke for a few seconds when started but it never smokes when driving normally.
Body wise it isn't great, i think every panel has either rust or a dent.
I will get some pics up later once i pick it up from the garage and i'll add prices then too. But i'm open to offers on everything.
Questions welcome.
Ash
  • Replies 88
  • Views 4.3k
G40 brake calipers
Questions welcome.
Ash
Hi mate, I'm after some clear indicators and side repeaters. You got anything?? Cheers Gav
How much for the front lower strut brace collected from Ilkeston?
I'm after some GT seats front and rear. How much you want?
PM me please.
what sort of strut brace is it?
how much u want for it posted?
PM me a price for the front Gt badge please mate?
Price as a whole?
Price as a whole?
Same.
Sorry guys been abit of a hectic weekend, for the whole car i'm after £350 ono as I could get abit more for it in parts I think. Keep in mind it has the adapted GT inlet manifold which I could get a good price for as there are a few people doing the 1.6 conversion atm.
I forgot to say the front drivers side got reversed into last christmas so the usual suspect items are knackered (less then 5mph impact but the head light plastic shroud is broken although the head light is ok iirc, bent wing, corner of the bonnet. Basicly the shell is pretty rough now. :lol:
It failed the MOT on a few things:
Welding needed around petrol tank area - tank out and around 4 - 5 hours patching/welding. It says on the MOT sheet that its close to a seat pelt point although I havn't seen it for myself yet and the brakes need a total overhaul really. The exhaust is awful and it needes a CV joint and boot on the passenger driveshaft.
GT badges front and back - £15 (the back one is a little faded iirc)
Not sure what make the brace is but it fits perfectly so I would imagine its a good make. £25
Not sure I would split the interior this early on as I would rather sell it as a whole - £80 - The fronts are mint
How much for the engine, inlet and box collected from Ilkeston?
Engine.
GT Throttle body (dewedged) £25 SOLD
GT ECU £20
GT Loom £15 (needs re-wraping and one or two connectors need sorting out)
GT Injectors and rail - £20
ABU Engine with Polo mk3 flywheel - £80
CL 5 speed box - £20
Adapted inlet - £100
£250 for the lot, that includes all the engine mounts,1.6 extended downpipe and a GT exhaust system although it blows quite alot, alternator, Golf gti afm and a Polo GT afm item.
The only thing you will need is a radiator as mine leaks and the water pipes from a mk3 Polo which you can get from a scrap yard for nothing.
Edited by carver
Some pics of the modded inlet manifold to fit the 1.6 block
Front seats
Also if anyone is wanting the car as a whole let me know asap as I will be starting to break it by the end of the week.
I'll leave the engine, but I'll take the box for £20. I can collect from Ilkeston, let me know when is suitable.
how much for interior mate?
Interestted at that - you about at the back end of the week?
For the interior - £80 which includes all the door cards, carpet ect.
Yeti - I'm around on Thursday if that is any good, other then that its going to be around xmas time when i'm back from uni.
both bumpers? condition? price? tar :-D
GT bumpers, iirc the back one has had a screw put through it but its not noticable at all. Make me an offer. Not after much for them.
Edited by carver
what was the screw for? erm, well i can pick them up as I'm only in keighley near bradford but not sure what to offer lol
I'm away til thurs, so probably won't be back til early hours of Friday.
If you break the engine I'll definitely take the dewedged throttle body. Cheers, Angus.
Price for gearbox and bumpers, collected....
Both bumpers - £20
Gearbox £20
Wont be able to get the box out until next week ish as I'm juggling uni and breaking the car, and the car is 70 miles from uni :lol:
