How to tell difference? :S
Might be looking to get a new polo, but i am after the 100bhp polo mk5. But looking around there are 75bhp aswell, and wondering how to spot difference, as many people dnt mention if its 100 or 75 model.
Cheers :p
  • Replies 31
  • Views 2.4k
The 100bhp polo has got purple injectors
Test drive =P
Does the 75bhp also count as a 1.4 16v? so can be listed as one?
Lol at test drive....duh :p
Best place to look its for a 6n2 16v is Autotrader. If the seller can be arsed to do a perfomance index it will tell u what BHP it is.
But i would double check b4 buying the car, some1 maybe pulling a fast 1 :ninja:
Bloody autotraders :p, ahh so is there any easy way of differentiating them? Paperwork??
Cheers :p
They have different engine codes, if you are able to look at the paperwork. Engine code AFK is 74kw (100bhp) and the AHW is 55kw (75bhp). This will probably be written in the owner's manual, but definitely on the sticker in the boot under the carpet. They are both 1390cc (1.4)
Edited by 6Newan
Can you make the 75 bhp version 100+ by changing the injectors?
Think the wheels are different aswell on the two, the 100 bhp have more spokes than the 75 bhps:
100 bhp
75 bhp
Nope
Apparently the 100bhp ones have front fog lights, and a front 16v badge, and rear discs. Purely what I've read on here though.
Nope
Then what would you need to change to make it 100bhp
The engine
This comes up all the time on here, from what I remember the pistons are different and so is the inlet manifold, and some other stuff.
But basically there's alot more to it than just changing the ECU or injectors etc.
100 bhp
75 bhp
Both of those are 100 BHP according to the Performance Economy figures on Autotrader.
My car has 75bhp according to a HPI, and my engine code is AUA.
Nope
I'm sure my 75bhp has rear discs, and i think the SE comes with front fogs too.
Ok, well I'm just recycling rubbish I've read on here then :lol:
Clocks then, does the 100bhp have higher reving dials?
You might be right. I might be just making rubbish up :lol:
But i had the back wheels off mine, and i'm sure it did have discs...
Yeah, both models of the 1.4 16v have rear discs.
oh well.... looks like some slow eco driving for me then!!!! :-(
Righttttt....so easy way to diff is the engine codes?? And about the dials, would 100bhp rev higher? like on the mk4?
Cheers people, bit more confident on buyin one now. :)
easiest way is to pop the bonnet and see if the inlet manifold is metal or plastic, if its plastic then its the 75bhp and if its metal then its the 100bhp model, i rang a VW specialist other day and he reckons its the Cams, ECU throttle body and inlet manifold
arnt the dials on all 6n2s the same, i have 140 mph on my 1litre dials :shock:
would assume the would change speed and revs together lol
different gearbox ratios mate, and no the clocks are not all the same, TDi's are diffferent, gti's are different, 1.4 16v are different and 1.0's are different
Edited by Jamesb
No, there are alot of differences.
Copied from another source
"the difference between the 75ps 1.4 16v´s and the 100ps is not only the ecu. The 100ps ones got an aluminium "ansaugrohr" like the old 1.4 16v AFH and the throttle bodie is bigger. The 100ps ones have a "Grauguss" (steel) crank case the 75ps ones got one from Aluminium. The crankshaft from the gti an the 100ps versions got 8 counter balances-->75ps only 4. the camshaft´s are different...
because of the aluminium crankcase you can´t change the crankshaft.vw say´s loosing the screws holding the crankshaft will destroy the structure of the crankcase?!?
But the 75ps ones are good to tune. fit 2 "schrick" camshafts the polo gti "ansaugrohr" inkl. the throttlebodie and you will geht close too 90-100ps (inkl a good chip for the ecu..)"
Alll 16v models have rear discs.
SE models do not neccessarily have fogs. Mine is a 1.4 8v Special Editions (SE) and it does not have fogs, alloys, or rear discs, or the deeper side skirts.
