We've sprung a leak captain!
After a rainy night, My late mk2 square's footwell front and rear is soaked through on the drivers side, is it coming through the door? Battery tray has already been repaired and it's a non-sunroof model.
  • Views 868
Could be your windscreen seal leaking, mine did! The rubber outer lip was folded in and water got into the seal and found its way into the well, not loads of water tho...
I just used a screwdriver to lift the seal back out and bung a bit of silicone in there.
I'll have a look at that tomorrow, mine has let in an awful amount of water, it's gone right under the drivers seat into the rear footwell :shock:
Ooh, nasty! Have a good look round, see if it's run down from anywhere, i.e. feel for wet patches. Either that or someones just dumped a bucket of water in for shits and giggles??!
