1.0 to 1.3
right got a 1.3 engine and just got my 1.3 ecu inlet and SPI....will it work on 1.0 engine loom? all the plugs look the same and same number of pins...also will my lambda probe be affected???
  • Views 1.2k
i have just done the same conversion with a gt engine yes it will work fine with the 1.0lt loom fuel pump ect
only thing you will need to adjust the gear linkage if you are using a 5 speed box but that is easy
and i would advise using a g40 clutch
gaz
its not a GT engine, thats later to come, already got a 5speed box done, engine is running with the 1.3 block, all i need to know is nowi have bought the 1.3 spi (55bhp) and ecu will it work using the 1.0 wiring loom
will get a g40 clutch when i wear mine out, tis a stong clutch still
yer course it will mate iv got gt block head box need cam with spi carb manifold need ecu on the standard 1.0lt wiring loom everything is the same pal
i know what i need for a Gt conversion lol, i never mentioned anything about the GT in the initial question lol...but thanks mate, glad i dont need to source any more wiring as of yet. cheers guys!
All the TB loom is the same. Should be fine dude :thumbsup:
Ian.
it is ian, its running fine, just some minor adjustments, and tappets then the engine will be sweet =]
