Sunroof HELP!
I have a britax pop up sunroof on my mk2 and its started leaking, i put duct tape all round the edge between the glass and the frame (not frame and body) which solved the leak on the drivers side but made it worse on the passenger side!
Which leads me to thinking that the leak is round where the frame sits on the roof (this was always a suspicion)
Anyway what i need help with is removing, resealing and refitting it! as far as i can tell its two parts held together with a series of screws possibly?
Looking at doing it tonight, going to put it in the garage, nice and warm and dry and give it a bash!
anything i need to know? what sealant should i use is household stuff good enough?
any tips for removing and refitting welcomed!
Thanks in advance
Matt
  • Views 756
Popular Days
Done it, hopefully it will have worked!
Came out as i said with screws all the way round then lifted out.
Cleaned and resealed it with sikaflex marine sealant so should be up to the job!
another satisfying job done :)
