heater knobs not lighting up
my heater knobs are not lighting up does anybody know what this could be, cheers
  • Replies 14
  • Views 1.4k
bulbs either come loose or blown behind dude...
the fascia [panel is clipped on pop it off with a flat head driver but be careful and you will sreee....the dials light up with a bulb behind the center dial
yer mate i have done this i was working the other day and come today it does not, there is also little metal rods on there but was scared to take them off incase i couldnt get them back on or is that simples? cheers
mine go on and off all the time mate just give em a good whack n they will come back on lol =]
Haha shall try this later on mate cheers
Just fiddle with the bulb! Mine goes off all the time....as a matter of fact, it's off right now lol.
haha how exactly do i get to the bulb? cheers
id check the fuse before you try this to be honest get to the lamp consists of stripping parts of the dash down !
??? stripping parts down 5 min job with a good old screwdriver lol
wait no scratch that it takes about 30 seconds to do =] thats roughly the same time it would take for u to get the fuse out check it and everything lol
oh and you just take the little piece of plastic that surounds you are heater knobs then unscrew 4 screws and you are there my friend =] simple as
On the mk5 getting to the bulb takes 0.5 seconds.
Just twist to 0 and pull the knob out lol.
there you go you see now u know how to whack a 6n2 bulb out aswell lol and that takes less time than checking a fuse :o
what did you pull the nob out with "some one said twist to 0 and pull" i tried it and i couldnt manage it, could barely fit enough fingers on there to get grip lol
Try a small screwdriver - like the sort you use to mend glasses, down the side of the knob.
Worked for me.
we still talkin bout the 6n2? if so ill give it a try thanks.
