how to take front seats out in 6n
hi lads i wanna take my seats out on front but i just cannot figure it out how or were to open to take them out has any one got any diagram or took them out before cheers for help
Matt
  • Views 879
I'm not sure on this but from previous attemps on a few cars on a mk2 polo if ther anything like that thers a little 8m bolt and the front undo that and it wil slide out but as i take it you are car is newer slide the seat right back and have alook on the runner and ther should be a 8 or 10m bolt ethier side and the same at the back just undo them and you are on you are way might be wrong tho they might be somewher else but i gess looking wont hurt hope this helps :-D
At the front of the seat by where the lever is to slide it back, there's a bolt, undo that..
Then go behind the seat to where the runners are (the bits of the car that the seat slides along and are full on horrible yellow grease. One side has a long plastic cover over it, remove that (just pulls up and out) then remove the small platic cover from the other runner.
Tilt the seat forward (makes it easier) then slide the seat all the way back and it will come out.
Really simple once you've done it.. one bolt, 2 bits of plastic, remove..
yeah thts were i had problem with 2 bolts hah i undone them ones on back and couldnt work out what to do next
but thanks for help :)
