orangey peel :S
just wondering if someone could explain what it is why it happens and how to rectify it??? pleaseeeee =]
  • Replies 12
  • Views 1.4k
i just got a rag with a slight dab of tups on, be extremely careful though!
It smooths it off, but you may need to re-spray it.
Max
How bad is it -ie: limited to one panel etc
Try wet sanding it -be very very careful though, and then machine polish to even up the finish.
Detaling World have a decent number of threads on this sort of thing dude.
funny thing is iv only just started this spraying job and had a spare vw badge lying around so i thought id have a bash on that and its gone orangey peely like... I'm not too fussed about the front badge but when i come to take paint to the car i would like to keep orange peel to a minimum so is there anything i can do to stop it?? and by tups I'm guessing u meant turps lol??? like white spirit? thanks alot mate =]
Crap totally mis-read this haha :oops:
first bits if you wanna get rid of the peel effect :lol:
Cause: Paint is drying before it has a chance to level
Fix: Sand to level the surface of the paint once the paint is thoroughly cured
Solution: Heat the paint (spray cans), Move closer to the subject
Tip: If you move closer or heat the paint, you will be increasing the amount of paint you are laying down so you will need to move over the panel/car faster
Edited by pocketrocket
thanks alot mate i sanded it down but then sprayed 2 coats of clear lacquor on and it went orangey i dont mind cz i think the badge looks pretty cool in white lol and also I'm gonna do what u said about heating the cans up when i get onto the car thanks alot mate =] happy days
orange peal is down to the lacquer mostly the paint is fine, its all to do with how the lacquer is sprayed onto a panel or in this case your badge and the way it sets, if it lies flat to dry the lacquer gradually spreadys out evenly but can still be a tiny bit peally, if you look at just about any car with factory paint they all have some sort of orange peal, i never let a car leave the workshop without flattening the panel with 1500 wet then 2000 wet and machine polish with G6 a few times then give it a few coats of wax, to have a perfect flat finish you can paint and lacquer the panel then rub it down carefully with 1500 we making sure not to rub through the lacquer and once thats done re lacquer it and it will be immaculate
Edited by jordan eff
Too heavy with the paint,coat's too thick. Skin dries,then paint underneath shrinks as it cures,causing a fingers-in-the-bath effect of crinkling up.
Apply thinner coats,allowing in between coats coat to dry. Or patience,for short.
^^^ haha that kinda sounds like me :\ i lack patience and therefore wind up spraying coats about 10 mins after the last trying to get it done before work this morning lol
chemicals and contaminants that react with the paint, final wipe and tak cloths should reduce it, if not solve it.
A tack cloth is to remove any fine pieces of dust or dirt, panel wipe degreaser removes contaminents. Neither of these get rid or help orange peal
yeah I know what there for thx, it seemed to of solved it for me :D
Its not orange peel if its reacting with something (stuff that a tak cloth gets rid of) its just a chemical reaction with the paint causing something that could look like orange peel.
I got this quite bad when practising at college. As i did more panels i got quicker and it slowly got better.
Must have been putting the paint on too thick.
