Polo gti 5door seats into my 6n 5door?
Are the front and rear seats a straight swap over? Not fussed about door cards so might have some for sale! Tony
  • Views 662
as far as i know if its the 6n2 gti then yes this is a straight fit =] rear maybe need a bit of modifying depending I'm not sure as my 6n L spec doesnt have split back seats :\
Yep they are a straight fit but as said if you have the L model 6n which does not have the split folding rear bench then you will need a little bracket that screws to the body but you can get that from any 6n but not the L 1.
or just deal with the fact that you are back seats constantly nearly fall into you are boot =]
