Mk1-3 Polo 1.4 16v FAQ + Conversion Guide
Has anyone adapted digifant injection to work on a 16v? Is it up to it? I'm guessin they could build a chip to suit?
  • Replies 224
  • Views 103.8k
  • grungeisdead
    grungeisdead
    Fitting Bike Carbs in a mk3 So anyway. To the meat! What do I need? 1 x Mk1/2/3 Polo ENGINE 1 x 1.4 16v (AFH Engine Code) out of a Mk4 Polo 16v “Valver” Engine Mounting Plate GEARBOX, A
  • shipleym701
    shipleym701
    Hey guys. Rang VW about that G40 Oil T-Piece. They said something about a banjo fitting that comes in two separate parts. Works out as about 40 quid for the two. Does this sound right? I was g
  • Wrong topic. But those carbs are set up for a 1.6 8v and the manifold is for a Ford 1.3/1.4/1.6 CVH 8v engine. Carbs themselves would be fine for a 1.6 8v Polo.
there is a lad on here that has cut up and mated a 16v and gt inlet manifold and is running it on the gt digifant on the standard chip. he say's it runs fine, but how it compares to the standard AFH set up i don't know?
may seem silly questions but how much in lenth and how you know what size fuel line to use
ill be doin the t peice way
also alinnement of the cluch i hear you can doit with you fingers any tips on this as ill be putting a new clutch on
cheers
I was wondering about when I was reading this. You say mk1, mk2 and mk3 polos.. But with the mk3 do you mean the mk2 facelift or the polo from -94? And also that will help me know what which model you mean mk4 haha :)
Thanks Adam
Edited by Farnsy
mk3 as in Mk2F so cars up to 1994
Ok ;) I always get confused with that
cheers
Trial by fit,8mm id for all hoses,10mm for the hose's directly into the carbs(i use the proper bike hoses) with an 8mm to 2x10mm t piece. For the clutch just do it by eye its not hard to see if its alinged but you'll be Pissed off if it ain't after refittin it all! If its your first time get a clutch alingment tool!
so ill be doin mine carbs on a 1.4 8v aex engine ,750 bike carbs
do you have to use the parts bellow as i got told i could use mine from the mk3 engine?
and do you have to use a facet pump or simmler or will it run of the under car pump?
Facet Solid State Pump
Mk2 Polo Distributer
Mk2 Polo Ingition Amp
Mk2 Polo Ingition Loom
Mk2 Polo Coil
and last of all do i have to put the servo vaccum on the inlet manifold or can it go anywhere else?
cheers
Edited by 01mlacey
servo vac comes from an area that has a vacuum, your inlet manifold has a natural vacuum and therefore is the place to take it from. ideally you should use all four ports and use a one way valve to negate pulsing which can cause a funny idle.
you will need a low pressure pump, or a turbo regulator fed into a low pressure regulator. id prefer the simplicity of the first.
who told you, you can use mk3 parts? if your confident you can heed their advice, but id say read the mk3 bike carb faq thread and all your questions should be answered time and time again
any reason you've chosen 750cc carbs? I've found my 600s to be perfect for my 1.4 16v and although i didnt have teh 1.6 16v engine running for long, the carbs didnt feel restrictive
yeah I've read quite alot of all the bike carb threads
the reason i used 750 carbs is because i bought the engine and carbs from a mate and thats how you ran it ,exept he ran it in a mk2
matt way on here who lives local to me said i should be able to use my mk3 dizzy,coil ,ignition etc
I'm just clearing things up reli
so back to the oil pressure senders.. why do you use both? surely you can only use one?
I've just got the low pressure one plugged in :)
Hi everyone, I've got a mk2 1.4 16v on r1 carbs. I need to fit a choke cable coz its a pain.to start when its cold. Could I simply adapt a standard mk2 choke to fit? Cheers for any help
As long as the Choke on the R1 carbs is a pull/push one then I don't see why not. I fitted one to my CBR 600's and it worked fine but I took it off as I had no problem starting when cold.
if your choke was manual it should be quite self explanatory!
YeH it is push and slide. No the car wasn't originally a manual choke, but thanks for your help guys!
will any regulator work or do you need a certain one
cheers
Depends how you are regulating it!
If you are going from an injection pump you will need 1 high pressure and then a low pressure one to go to the carbs.
If you are running from a Facet then just a normal pressure one would do the job.
Check out the bike carb thread in the FAQ... explains all.
Not specific to this engine but you only need to fill the bowls of the carbs so doesnt matter which engine its on (within reason).
Hi there all,
This is my first ever post, just want to say that i'm totally blown away by this engine swap concept and how comprehensive all the information in the build threads are. Every time i come up with a stupid question an answer is only a bit more digging away. Thank you all for an amazing job all round.
Finances permitting i'm hoping to take the AFH challenge this summer.
Edited by Hammerheed
Cheers for this saf you legend, hope to see you and ad when I do mine haha :)
when u use mk2, do you class upto 1994 as mk2 or until 1990?
thanks max
thanks max
to 1990 :)
cheers mark, your guide is going to be a big help :)
  • 3 months later...
i'm on the brink of buying this for the oil pressures... reckon it'll work?
website
Edited by arron0909
yes...
