mk3 gt power?
just looking at buying a mk3 gt,car has full exhaust system, 4branch manifold,uprated ht leads and plugs, and has a poloace 8kchip? will it be quick? whats the deal with the 8k chip? cant find any real info on them, they any good, does it help the car alot? also does any one have any info on what would be best to add next? was thinking cam but unsure whats best so help needed guys please
  • Views 625
GTs are 75bhp as standard. With the exhaust/4 branch, add another 2/3bhp. The leads & plugs won't really add any power.
The 8k chip you speak of will cancel out any flatspots and generally make the car feel more lively although after 7000rpm, it's just more noise and no extra speed.
An induction kit and golf GTI air flow meter is a good mod as well as an uprated camshaft. If you crave even more power, the bottom end from a Golf 1.4 engine (ABD code) will give you more torque.
If you use the search function, alot of info can be sourced that way as it's been discussed many times before.
