removing rear badge?
I'm being lazy and cant be botherd to use the search function,
does the read badge on my mk2 just pull off?
thanks
ash
  • Views 1k
Get some fishing wire or something and use a sawing motion behind the badge, if you just pull it off you risk pulling the paint off. Thats what i did on my mk4, i presume its just stuck on on a mk2.
My scirocco actually uses holes drilled into the metal with plugs attached for it to hold onto the boot, at a guess, with it being a MK2 is that it would be the same. Could well be wrong though but I'm just going by car age.
Just get your nails behind it and pull. It does have the drilled holes and plugs like the rocco. Unfortunately you wil be left with holes in the metal work, which will have to be filled
Thats right anus, I was gonna debadge my mk2! Won't bother now, it would be damn near impossible to match my faded paint!
