Is there holes behind this badge when I take it off?
  • Replies 13
  • Views 1.5k
I'm 98% sure there are No holes mate,
never done it tho. shudnt see why there is holes when they dont put holes in newer polos.
there are 2 holes!
there are 2 holes!
Damn! 100%?
Will have to wait until I'm getting the wiper welded up then :(
all mk3s have two pins there - unless its been welded in hte past
there are 2 holes!
Yep 2 holes :nod:
u should take it out, rub it down and colour code it to your car, looks good!
or just t-cut it and make it black. that silver comes off easy
yes, 2 holes
yes, 2 holes
Might do that, was going to paint it but T-cuttting sounds like a better option.
Cheers :D
sorry to hijack the thread but what about the other badges on them?
(e.g. 'coupe' and 'boulevard' etc.)
pretty sure there arent any but dont wanna try and prize them off and snap the pins.
yes, 2 holes
Done, :D
The only one with holes is the "polo" badge, or "polo_cl" or whatever :thumbsup:
sorry for wrong info!
the holes are easy to get rid of on a budget if you want the clean look.
1.take the plastic backing from the inside of the boot
2. reach inside to the inner side where the holes are
3. stick some stiff tape over them
4. filler over the outside of the holes, using the tape as the surface for the inside, tiny bit of filler, then just spray it over, even works just using a touch up pen.
