coupe or coupe s?
I'm just wondering weather my polo is a coupe or coupe s? as on the logbook it jus says coupe. and on some insurance sites it comes up with coupe s. also i have the red striped trim around the dash clocks.
and its also a b plate
  • Replies 10
  • Views 1.6k
dus it have a coupe s badge on the back
nah, only had a polo coupe badge on it when i had it. not even a vw one as it was missing
Easy answer: It's a coupe.
Long answer: It's a tricky one... originally, the Coupe was the sporty polo, with the 1093cc engine, stripey (but not bolsterred) seats, revcounter, wide steels and external pinstripes.
Then as time went on, VW added niceties. a 1272cc HK, bolsterred seats, foglights, alloys as an option. This wasn't all at once though, they trickled them in. Likewise, the S badge got trickled in too.
And then, they chucked a 1 litre and a C spec on a coupe shell, and it was the Polo Coupe, as opposed the Polo Coupe S.
Then there's the Polo Coupe CL.
And somewhere, for some reason, a load of Polo Coupe C's, got specced up with 1.3's and seats.... I drive one, it's an oddball car.
Under the middle of the slam panel,there's a part of the front panel structure where the bonnet catch is bolted to. A bracing,its behind the grille badge.
Should be a plate on there,and the last one or two digits are kinda seperate.
What is/are those digits?
does it have like a barcode on it? if so there are 2 sets of rows of numbers
Also my coupe is the 1.3 hk engine the wider steels and stripey seats and the external pinstripes
Sounds the same as my B-reg. It was that spec but with flat stripey seats as opposed bolsterred ones.
I've seen a couple of coupe s' on here tho with the same seats as mine and on ebay
does anyone know that if a coupe s says 'coupe s' on the logbook or just 'coupe'
My '88 F reg Coupe S does say in on the V5 'Polo Coupe S' and has the rear badge.
You have a Coupe, not a 'S'.
