Rear wiper blanks
I'm looking to dewiper my 6n 16v and looking for blanks (if thats what there called)
Where can I get one of these?
Thanks in advance
Sean
  • Replies 10
  • Views 1.2k
Thanks in advance
Sean
www,venommotorssport.com glass rear wiper blanks £23.00
do you mean the like gromit you stick in the whole ?
and then the rubber seal to go over?
if you find out will you please let me know were you get this from?
cheers
cheers
na mate it's a smoked glass blanking plate that's glued in the hole
Thanks in advance
Sean
that wont fit a 6n
no not the grommet, the plastic cover to fill the big trapezium shaped gap in the rear screen, justmatz used to do them but they discontinued them for some reason.
make your own
sam R made a couple from an old number plate with a jigsaw & sandpaper! can easily be sprayed aswel
i made mine.
if youve still got the wiper, take the plate that goes over the gap...yes it does have a hole in it but...
stick a 2p on the back, wack some filler in it, flat it down, prime it and paint matt black.
thats what i did and then stuck it on using windscreen seam sealer.
i made mine.
that would just be waste of 2p
we are in a recession you know??
but on serious note ill try this pal cheers
I took all the wiper off and went to halfords and got the gromet for £1.30 and then used contact adisive to stick the plastic bit bk on.....:)
i made mine.
I'm sure youve got a 2p which has fallen unloved underneath your drivers seat haha.
i did it at work so i had all the materials i needed...inbetween doing my work it mustve taken me about 20mins...if that.
Thanks for the replies, must try make my own the weekend so!!
