Mk3 polo buying tips?
Going to look at a mk3 polo genisis in the next week and as I'm new to polo's wanted some advice on what to look out for when buying. Any problem area's or faults that are common? Any advice will be loads of help.
Look in the battery tray as they are prone to rust. As is around the fuel filler :) Mainly check for rust, then look for things like smooth gear changes or any whines :thumbsup:
Whats the mileage? Look at service history, cambelt changes that sort of thing. How much is it up for?
look for uneven tyre wear. seen a few with horrific tracking.
Check when the cambelt was last done - though its a DIY job for £8!
Battery tray, fuel tank (where the neck meets the main tank), rear sills, doors and tailgates all rust quite nicely!
Shocks would be starting to go at this age too, dependant on use etc.
Good luck - i've got one, a project really but its a sound car.
All of the above, plus the rear exhaust mounts are pretty awful - if they look rusty / flimsy chances are your exhaust will be falling off soon!
Mine sure as hell did!
Same :lol:
Yeah, take some cable ties with you for the drive back home :lol:
