Help!
As weather getting colder, I was going to add some anti freeze into the round water tank. but I just couldn't manage to open the cap!!
I tried unscrewing the cap anti clockwise, but it wouldn't move a bit. it felt like its STUCK! :?
it's been a few months while since last time the cap was removed. I think i might over tightened it last time?
What should I do? are there any tricks that may help to open a tight cap?
THANKS!
  • Replies 19
  • Views 1.5k
Put some boiling hot water on it perhaps, around the edge of the cap, that may help.
they do get stiff just put lots of force on it and it will budge
get some kind of leverage tool
i wasnt calling you a tool then either, it sounded like i was
:lol::lol:
Got it off yet? My rather creative suggestion would be to put a nail in the side of the cap then wrap cloth round it and pull hard. No idea if it would work, so might be best off as a last resort :).
Rubber mallet?
Could always bust out those mole grips :lol:
someone hasnt had their wheatabix!
you could try a hammer and punch on one side of the bit normal people just twist, or you could just find a mate whose a bit stronger and get them to do it
Once you've got it off go find a cap with the slot in the top of it. Then next time if it gets stuck you can put some sort of bar (screwdriver usually) in the slot and open it.
2 hammers. batter each side of the handle.
in a 'get it off' kinda motion.
i had nice experience with one of thes caps not so long ago,
had a overheating problem on my 6n2 ( later found it was a shagged thermostat and corroded fan switch )
i noticed steam comming from my coolant cap, realised it was very loose went to tighten it, Bang... Heavy burning to my hand, Worst pain in the World! lol
and a permanant scar to my thumb where at 50p size blister Poped, yellow Goo all over my steering wheel for the win!...
they usualy get stuck due to Cooland and water stangnating ( or whatever ) jamming the thread.
hammer to the Hand griping area works well, so does the screwdriver - same way as open a piant can, only loosening it tho :p dont snap it off :)
infact I've just noticed, it is god secretly telling you not to put anti freeze in your coolant.
haha. oh to be naiive.
Get some mole grips, clamp them onto the twisty bit and turn it. Mine always becomes hard to open, so i always use this method.
Thanks for the suggestions!
i tried again today before leaving work.. still no luck, but will try again later tonight before the snow comes (with hot water and screwdriver) :?
I know this sounds obvious, but i started questioning myself now...
can someone confirm to me its definitely ANTI-CLOCKWISE for OPEN?
(my car is a polo mk3 1.4 cl)
Thanks again guys!
Yes it is a normal thread, lefty loosy etc.
Mine gets a bit ight aswell, just hold some kind of bar to one corner and hit the bar with a hammer, should free the cap up nicely.
SUCCESS!!!
here's what i did:
i first covered the cap/top of the tank with hot wet towel for a while, then forced a screwdriver into the gap under the cap, then started knocking it with a hammer from right to left, at one point i could feel the cap turning slightly, it was freed! just like that.
thanks for all the good ideas. i can't believe i was troubled by such a simple thing :smile:
please dont put antifreeze in now lol
