Lots of 6n polo questions!
Right basically i have a list of stuff i want to do to my standard 6n and i need a bit of advice on how to do it :)
I want to change the gearknob to a 6n2 item, is this just a screw off screw on job? And how much are they roughly? Secondly i want to clean out the whole interior of the car, is there any way i can find out how to take the seats completely out? And whats a good product to use? theres stains absolutely everywhere and it stinks :( and I'm not sure if this comes under the right section but i want a badgeless grill and clear indies with 6n2 rear lights, i would probably get the rears from a breakers but I'm not too sure on the clear indies and the grill?
Finally does anyone know how much it is to get dents pulled out? i have quite a big one on the rear quarter and the arch is sort of flattened too on one side? Cheers for any help :D
  • Views 699
To get the seats out:
Front seats, if you look at the front of the seat at the bottom there is a small allan key screw, simply undo this and then move the seat all the way back and it will drop out of the rails and will be able to be taken out of the car.
Back seats, take off the top half using the tabs on the top left and top right of the back seat and you should be able to take the back part off. As for the bottom part where you sit, lift these up from the back and you will se how they are attached. There should be a small clip on the left of the car, right of the car and possibly in the middle, simply prise these back with a screwdriver to get the seats out.
For the carpet, use a household carpet cleaner or if you're feeling fancy, I'd reccommend AutoGlym carpet shampoo or interior cleaner whatever it is called, usually does the job well.
6N2 Rear lights, good luck finding them at a scrappies. If you don't manage to find them, get yourself on to ebay for the parts, or possibly on the for sale section in here, you'll always find the bits you need for your car in either of these places.
I've got a chrome badgeless grill if your interested? Drop me a pm if you are.
