Dashboard squeak & Removing centre panel
I've got an 6n and it has developed a really annoying high pitched squeek, somewhere around the air vents, or under the dash board above them.
If I touch the top of the dash above the vents the squeak stops, the problem is that I can't drive like that and it is a near constant noise.
Does anyone have any tips of what I need to do to stop it? Is it easy to get the dashboard trim (where the air vents are) off?
Edited by kapow
  • Views 1.8k
Bump...
Please help if you can! It is like I'm being tortured!!
Bump...
i have same problem on my 6n, and the 6n i had before this, really cant stand it, some1 must know how 2 stop it? come on they all sqeak lol? anyone? I'm being tortured aswel! i can get ma hand round tht area wen i have dials out, think am gonna av 2 av heater vents out tho 2 get right 2 the area of the squeak? some 1 must of fixed this, come on share the knowlege lol
Bump...
It is just by the heater vents, somewhere above them I think. As soon as I touch the top of the dash (with only a little pressure) it stops. I think I just need to get the black panel off and the vents out and it I will be able to sort it. I just have no idea how to get that panel off!!
Bump!
Please, can anyone help? I know that the centre black panel is attached the dash at the bottom with screws, but how is it attached at the top?
Is it by clips, or by screws from behind the dash??
hmmm, i had this in my 6n2, drove me 'literally' to insanity!, i found it to be some screws in the passenger footwell to be abit loose...
Solved this on mine, its the "6N Squeeky dash" problem. You have to take out the large cubby hole under the heater dials, its the larger plastic one that recesses into the dash at the bottom of the console. Once this is out, there are 3 main large bolts which are slightly loose, once tightened up your squeek will go :)
