how reliable is the g40 engine?
am in the process of looking t a polo g40 an as wondering how reliable the g40 engine is??
  • Replies 11
  • Views 2.8k
one of VW's finest :wink:
Edited by OLOP 1L
as well as it has been looked after... like any other really, baring in mind that they will need a little more love because it does have a supercharger.
Standard they will be a very reliable daily.
Its the ones that are played with then ragged everywhere that are the problem.
mines done 156k without too much trouble, so i'd say its pretty reliable
From my experience of them (my mate had about 3) they just need maintaining... if it's been maintained it'll be superb.
My mate has a G60 which has had a lot spent on the performance and it's got to be pushing over 250bhp but he has receipts of about £12k in maintenance!!!!!!!!!!!!!! (he's had it for a long time!).
I would say though if you want trouble free motoring and don't have deep pockets at short notice then don't get one.
cheers for info everybody ,dont no much about them as av started with the 1.9d mk4 polo wich is solid car,pure work horse but i just miss power,I've gone from a 2ltr redtop nova @around 200bhp to this 1.9d polo :cry: (sorry to mention the nova)
as reliable as a 15+ year old engine can be really. If it's been looked after and is fairly standardish then it'll be fine. If it's been ragged without much maintenance then it can be a money pit. Buying any older "performance" car is always a bit of a gamble. The most expensive part to go wrong is the charger so you need to check it's been serviced, on a standard pulley then probably every 40k or 5 years, if it's on a smaller pulley then as often as every 20k or 3 years. Always make sure the seller has proof of it being done if they claim it's been done. If the charger hasn't been done but it looks and sounds ok, no obvious damage, no knocking or rattling noises with the engine running then it can be more of a bargaining point than a reason to walk away. But you'd want to be spending about £350 right away to get it serviced. Disconnect a boost pipe and check that there isn't excessive oil in there as this more than likely means the oil seals in the charger are shot.
Otherwise just look at the general condition of the car, there's nothing special about a G40 shell other than that it says "Polo G40" on the log book so personally I'd rather buy a conversion that is in good nick with no rust than a tatty genuine G40, even for the same money.
as best you can, try to check the chassis legs in the engine bay for ripples, bends and cracks where they meet the bulk head as they can sometimes rip themselves apart here.
as for pullies, 65mm is the lowest you want to use, it's highly unlikely but if it is running on a smaller pulley than that then it's more likely the charger will be damaged due to over-revving it.
The only non engine thing you forgot Paul was the battery tray :lol:
You'll need to make sure it's not rusted through.
very reliable - both modified and standard, give it a good service and give it some love every month and it will never let you down........
till the charger needs a rebuild :roll: .
Edited by genesisGT
