................. ohhh poo
had bit of a ...........oh poo moment today :-(:-( had a pants day at work but was looking forward to getting up my m8s workshop to take suspension of my mk2 bready and drop it. all was well and good, front all out ready for new bearings to go in aswell tomorrow, got 1 side of the back up and put new shocks n springs in, all nice and easy, went to put wheel back on and it now wont fit!!!!!!!!!!!!!!!! :shock: the new springs catch the wheel as they are about 3" longer and so come down lower than standard, I've got 2 options now, big big big expenive spacers and alot of archwork or 13"s, :? the 13"s fit fine only being 4 1/2j but i really wanted to put my teardrops on I've just refurbed, has anyone else ever had this problem and what did u do? lol
  • Replies 16
  • Views 2k
Lol, i'm actually anticipating the same problem, just ordered a PhilJ kit but I knew i'd have the same problem so i'm also getting a pair of rear Mk1
golf coilovers from a guy on here as they're a bit slimmer, roughtly 8cm i'm told, so they should just clear the inside of the wheel, I hope...
What is the width diameter and offset of the teardrops (I know shit all)?!
it wasnt the tear drops i tried, I'm still painting, i have been running 6n alloys as they came with the car, they stand no chance of ever going back on as the offset is wrong. the teardrops are a 6j with 38 offset, tried a steely that is the same and wouldave needed a 40mm spacer, then the arch is in the way. this is on a setup from phil, there ta tecknik i think. I'm condering putting steelys on then banding them out to the arch, its a pain in the arse........................ wanna buy some satin black teardrops, lol
Are they ET38 teardrops? and what tyres do you have on them?
I know that these are the limit in terms of fit on the rear of a square but I didn't think they would interfere with springs, thought it was more of a persuasion of the rear arch than anything.
Get some pictures up (in the wheels/tyres section) and I'm sure someone in the know will have answers..
yea there et38, will get some pics up after there finished. would have gone on no problem but the springs interfere as they are lower on the kit iv got :(
what tires r u running? the rear on my mk3 bready rubbed on the spring when i put the 175/70/13's on my hokenheims
^^^^^^ How low was the rear on those 175/70's bud?
What 6n alloy are they?
If they are the indianapolis ones they are ET43.
Teardrops should fit though being a lower ET.
ye the 6n wheels are 43 which i no is wrong, wasnt planning on keeping them, just on the car when i got it, tried a steely with same sizes as teardrops and 175/55 tyres and hit the spring, needed 50mm spaces to miss :( have put some 6n 13" 41/2 j steelies with a 35 offset and there spot on, and i like them :grin: :grin: maybe banding them is in order
I've got 6.5J's at ET33 and they certainly dont interfere by 50mm, 20 would definately clear it.
I'm a bit confused,I'm on TA Technix with 185s on 5.5s at et38,and have used 6x14 et38 Golf MK2 alloys with this kit,and have no issues. Nor have i even heard of such issues before.
Are you sure the damper is on the right way around,where it bolts to the axle?
Definately check this.
middle notch down mate
theres only 1cway it can go on, its a straight shock with no bends or or angles where it bolts on, the spring sits much lower on the damper than standard and is much wider than standard aswell
i understand what you mean. your on about the rear shock and spring right? what wheels are you running? I've used 13s, 14s and 15s all on phill j shocks. think i have my rear ones set to the highest point. tried them on the middle point and they just looked daft. I've never had problems fitting wheels though. you must either have strange wheel offset or stupidly wide/big tyres
I'm now running 155 55 13 tyres on steelies with a 35 0ffset, iv got it pretty low at the rear, 2nd from bottom, think I'm gna stick with these and band them and play with the arches to accomadate them :-D :-D
my 14'' 6J teardrops didnt fit properly on the back of my breadvan, had to smash my arches a bit, but then again, it is lowered by about 100mm at the back. they tuck in really nice now though, the tyres scraped the inner arch before but as i said, a hammer and a lump of wood sorted that out.
