Remove 6N2 Wing Mirror
Just need to know how to go about doing this, as I'm replacing the outer shell as my current one is cracked
Pav.
  • Views 4.5k
If you're changing the outer painted cover, you do NOT have to remove anything. The painted cover just slots on vertically to sit on door mirror. Remove the old one carefully and replace with the new one.
Where did you get the cover from and how much, may I ask?
PoloD.
Havnt got it yet mate, I'm going to take my current one off and get it plactic welded and smoothed then resprayed in gloss black, a close mate is a sprayer so it works out cheaper.
But check ebay or the scrappy, they are the same as ones of a lupo and ibiza's if yours are stubby
  • 6 months later...
can anyone elaborate on taking the cover off? I just can't get it off :\ feel like I'm going to break something
you literally just pull it upwards, most plastic things on cars seem to feel like they're going to break when you pull them off, but usually don't!
just noticed there's a screw on the underside, do i need to take that out or is it not attached to the cover?
