L reg... M reg
did the polo change from L reg to M reg mk3's??
my coupe was M reg and has a different ECU to my earlier one.
also, my haynes manual only goes to L reg.
  • Replies 8
  • Views 1.2k
my GT is a L reg 1994, a late one!!!
m reg is where it changed to the 6n, ( not good at explaining so bear with me :lol:)
They could have put an ECU in the MK3, with different settings, and that got carried on to early 6ns, if you get what i mean haha
is it the same engine as your old one? they randomly stuck multi point 1.3 engines in some mk3's maybe that's why?
The very last mk3's (late 1993-94) had iirc 26 pins on the ecu as oppose to less on ealier mk3s, i don't know why. also the late spec mk3's have the tinted rear lights and the speedo unit does not have the water temp warning light, making finding one with a rev counter an absolute pain in the backside! also they oil pressure sensor is slightly different to on the earlier models.
1994 on the M were mk3 polos and 1995 on the M were mk4's.
There were a lot of modifications done to the late mk3 polos as already mentioned above, yours was probably a 1993 L reg which missed these.
Yeah I've got a really late one, ECU is different to earlier ones.
Mine's a late-ish GT Coop, too - made November 1993, registered January 1994...
Rich
There seem to be loads of differences with the final year of the 86c chassis,some very useful - the smaller starter motor and shorter o/s driveshaft with 6n gearbox drive-flange bearing design are items ideal for engine/gearbox modifications and maintenance on previous cars.
