Can you fit 9n Rear Lights to a 6n2
I'm just trying to find out because my dad had this brain wave.
Edited by Callumhall
  • Views 2.7k
no, they're a different chassis.
yes in the same way you could connect the wiring to traffic lights, but seriously no they won't fit in the hole!
Urgh i ment the rear lights
My bad.
Still won't go in mate!
It'd be a bit like trying to fit a triangle block into a square hole,basic spacial awareness being the skill required to consider such action.
Not as stupid a question as I'm making out,though - '79-82 Ford Cortinas and '83-90 Ford Orions have the surprising ability to have their tail lights swapped in minutes.
But one look at the shape of the tailgate where it shuts to the lamp on the two Polos in question,and the way the lamp is countersunk into differently shaped rear quarter panels,tells you that whilst it can certainly be done,it cant be done without major modification to the bodywork and/or lamp unit.
The latter gives you an avenue though - keep the 6n2's lamp housing and remove the lens. Then trim up a 9n lens to fit. Then partition the 6n2 housing to manage the new light areas and fabricate a bulb/LED platform for it. Then glue the 9n lens over that.
Easy? Doubt it,but it may be worth looking into if you think you could do it properly.
^^ What he said
