16x8s et25 on a 6n pic reuqest please..
Hey guys,
i have found a set of awsome wheels, there 16x8 with et25
and there 5x120 so will need 20mm adapters.
anyone got any pics of this setup or a similar 16x8 setup?
thanks
  • Replies 12
  • Views 1.3k
so final offset will be et5, gonna be tight!
any pics of the setup anyone?
There ace rims though dude,
3 peice splits is all I'm saying :p
what would need to be done to make these fit?
alot of stretch?
cambered?
arches rolled/ pulled
didnt poundie used to have 16x8 on the front?
pandas got 16x9s
your gonna have to do all of the above mate
but if there slick itll be worth it
BBS RS's?
arches rolled, 165/40/16 tyres!
arches rolled pulled out rear bumper may need flaring out to suit as this is the problem area with where offset and lows come into play....where the bumper attaches to the body!
i am running 16s at et10 on the rear and et20 on the front but only 6.5j
and the rears catch a touch (rolled) on dips at speed fronts are fine as my arches are rolled too.
i put those details into the offset calculator to see what the difference between that setup i have and the one you want 16x8 et5.
it says there will be 14mm less inner clearance which is fine, but will poke 24mm more.
pop in your current wheel specs and then the new ones and it wil give you a rough idea of how it will look on your own car dude :D
http://www.1010tires.com/WheelOffsetCalculator.asp
the joys of 16s is you have lots of tyre choice!
there 3 peice polished speenlines.
buy
there gonan stick out 2cm more all round :S
think ill have to have major arch work done for the right stance
so I'm not gonna bother
gay
Neil, Get them!!
agree with neil.....GAY!!!
you can get them pulled out that much cant you??
as if my schmidts dont pimp hard enough toby :Llol:
