mk2 steering wheel adaptor
need to fit my new steering wheel and boss, but theres an adaptor on the colum for the standard steering wheel. its basically an adaptor with both internal and external splines, so one goes on the coloum and the other splines go into the wheel! any ideas on getting it off, ie tried two bearing pullers but neither work??
any help appriciated
  • Replies 8
  • Views 2.4k
as far as i know the only thing you should be taking off is the stearing wheel itself, then the boss slots onto the spline, and your new wheel goes on the boss.... what are you trying to remove?
yeah, erm, take the wheel off, then theres a spline on the colum which is about 1inch wide. but my mountney boss is only like 1/2 inch wide, its the mb045 which fits the polo, golf, beetle, t25 and others. ill get a pic of it.
you may have done the same as i done about a year ago, and brought the boss for the polo but it's for the small spline models :s the spline size changed to larger 1988 onwards i think
yeah my boss is a small spline, it fits on my mk1 golf gti. but on the polo it looks like the wider spline is over a smaller spline, so can i be pulled off or cut through, and split off the colum, iwould just go and do it but dont want to find out, it dont fit and not be able to put the old wheel back on!
i had to take my steering coloum out on my golf as i had the mb045 but needed the mb070..but removed the adapter..
use plenty of head and a chissle and a mallet...keep t as they do come of in the end
take all the steering wheel surround off and hit the spline with a big fuking hammer!!!!!!!!!!!!!
try and heat it a bit if you can be easier!
but once u get t off it will be hard to get it back on! plus battered to shit!
Can you buy these spline-sleeve adapter dealies anywhere?
i used a set of bearing pullers to pull it off. if you put the legs of the pullers under the bottom of it(by a spring thats there) and the pullers will take it off. if you wont to put it back ok put the bolt from the wheel in and do it up it will push it back on..
you nead somthing like this
http://cgi.ebay.co.uk/Bearing-Puller-4-3-J...=item27ae3f1c73
