2004 Polo - Central Locking Question
Hi guys
Joined the club today, so sorry if this has been answered already... I have recently bought myself a 2004 polo 1.4 tdi and it has central locking, but its not remote central locking... i was wondering whether it would be possible to make it central locking atall? i mean would i have to buy a new key and then get vw to tweak a computer to get it to work?
Many Thanks
Tom
  • Views 6k
I have the same question - I'm new to this board and am just getting familiar with the search function.
I Googled for hours and found references to a "pump" in the boot that can be modified with a remote key kit. So far Mean Machine are coming up on all the searches I have done for a solenoid-less kit (i.e. the car already has central locking, I just need the remote bit).
What is odd is the lack of standard VW upgrade for remote central locking though. Surely if I bought the remote version, it would have a unit added to it to provide that funcationaity. Can I buy the VW standard add-on remote locking unit and keys instead of an unkown (and untrusted) add-on?
Regards
Pete
Simple answer is No. Why? Because VW uses different central lock modules for cars with remote central locking and just central locking, please see the ETKA diagram I have attached below. So unless you replace the whole unit, VW doesn't have an add-on remote locking unit and keys, because its not that easy.
So your only option is to install a Third Party Alarm/Central locking module, which will tap in the central locking loom, and solve your problem. They are fairly easy to install, provided you know what your doing :lol:
Gav
Hey Gav
Thanks for your reply, sorry i haven't been on here in a while!
Are there any third party alarms you would recommend?
any aftermarket alarm will work on it
the central locking is negative resistive and requires a 1k ohm resisitor
and the door triggers circuit requires diodes to work correctly
