Another door lock problem
Cheers for the guide(http://www.clubpolo.co.uk/forum/index.php?showtopic=167689) mentioned in tonight's other doorlock thread, I've got the passenger side one to do - if I can get it open in the first place.
Does anyone else suffer from the mechanisms freezing up? The key goes into the barrel, turns, central locking pump pops up all the buttons, the rear doors and tailgate open but the front doors remain locked. Wait until about 11am and then they unlock no problem, but if it's too cold they don't.
Separate problem - key doesn't work in the tailgate, how easy are these to sort out?
  • Views 788
I've had the same thing this morning. Both front door locks frozen shut, but the back opens fine.
You do get some funny looks from the neighbours when you climb in through the back catching the horn :-D
I'm going to try rubbing some wd40 around the door seals with a rag today. If that doesnt solve it, then the lock mechs are coming out at the weekend to see if theres anything that can be done to stop them freezing up.
I'm not certain about the tailgate lock, but it can't be that different to the door lock?
seen this a lot this time of year they will open from the inside i know not much help and tbh i carnt think how to fix it there going to freeze if its cold
Front doors on mine wouldn't open from the inside either, so that made it unsafe to use (for me to use, in my opinion! It's up to you if you feel safe driving it, or if you have no alternative but to use the car.) I've removed the plastic grommets on each door and given the mechs a squirt of WD40, and so far this evening it hasn't been cold enough to show whether it's worked or not.
