can you get in your car?
right, went round to car the other day too find i couldnt get in
i dont have central locking and the doors were frozen shut!
anybody else having this problem atm?
  • Replies 66
  • Views 6k
Haven't used the key in the door for years, remote central locking :-) Had that problem before tho, you tried the boot?
my lock was frozen so couldn't turn the key and never forced it as i dont feel like snapping my key. so i had to stand for couple of mins with my hands over the lock to heat it enough for me to open it lol. still couldn't get in my boot either coz it was frozen shut. :D
Kuszpit :)
my boot lock was frozen the other night, couldn't even get my key in the hole. just to top things off the bump pack thing i've been starting my car with (i've got a fucked battery) was in the boot.
i struggled to get in the other day,when i finally did i found that a big chunk of the door seal was now attached to the door? not good times
anybody finally got in and then because your car get so badly condensed the windows are frozen inside aswell?
my key wouldnt work in my lock the other morning so i heated it up with my lighter :-) worked first time lol, but then my window was froozen shut and i got hotboxed on the way to work :? ha
i heard pissing on the cures frozen locks
could be worse,i had a metro a few years back I'm sorry to say
anyways one day i came out in the morning for work,found the car frosted up and the handle snapped clean off
had a brainwave,and tried the passenger handle,fucker come clean off
had to scan the area for people and discreetly open the boot and dive the back seat :-) :-)
i went off cars after a few problems with them,hence the metro :-)
i get that every morning on the way to work and every night on the way back, as soon as i've cleared the inside it freezes up again. i've found hot water pured on the outside stops this though.
just watch that you use warm water and not Something stupid like kettle water as the sudden change in temp on the glass can smash it.
Kuszpit :)
It may be an old wives tale, but coating the door seals in vaseline stops them sticking to doors (apparently).
yeah i had this problem today
all the locks frozen solid
had to get hot water out
Yeah, had this a couple of times. Once you get the lock defrosted, get it well sprayed with WD40.
Frosting on the inside used to be a biiig problem on my first Hillman Imp, hot but not boiling water was the answer as the bugger leaked really badly(carpets out, let the water drain out of the holes in the floor job). Also used a window wiper to clear inside of the screen and carried a thermos of hot water if I was going out and knew I'd have no access to hot water when I returned to the car!
That vaseline tip sounds really good, though.
Kuszpit :)
i always use kettle water (save turning the boiler on just to defrost the windows lol) never had an issue, although tbf i'm normally too impatient to wait for it to fully boil.
i just pour hot water into my lock and it works. Although this morning i tried to unlock it before i poured the water, when it came to to locking it it wouldnt lock, the key turned but it wouldnt lock so i had to take the door apart took the mechanism out and put it back in and it worked haha. Although i had to do this in the middle of a blizzard, ended up getting a car full of snow :oops:
why bother with a kettle. just put make a seal round it with your mouth and breathe into it for few seconds. always works :-)
Only needs to be a bit warm and it'll de ice the windows, it's what I always do given the choice. Don't use hot as it can crack your windowscreen.
Luke-warm tap water for the windows,and GT85 on the seals and in the locks. No problems,easy life.
will WD40 not freeze too as its water based?? Could be wrong tho
Kuszpit :)
funny this, I wanderd up to my car. did the sly click of the "unlock" button on the fob. Sharp pull, Whoopsie. am in :)
lol u will soon be adding to this thread when your key fob battery dies and your looks ceased coz you dont use them :D
Kuszpit :)
nah, i do still use the locks sometimes. Besides, they get tested in the vw inspection service it has every 10k or 6 months lol
aparrently checked and lubed!!!
vaseline on your key and put it in the lock the night before ... wont freeze in the morning :)
Chris
