can you get in your car?
Could'nt get in mine today, boot opened fine though! :lol:
  • Replies 66
  • Views 6k
had to scan the area for people and discreetly open the boot and dive the back seat :-) :-)
When i had a metro managed to lock the keys inside and the spare snapped in the lock (frozen) so had to break into it in the snow outside a row of shops at night using a coat hanger
looked dogey as, was suprised the police didn't turn up :lol:
If any of you think of buying a metro.... Don't they're just rubbish... and damn easy to steal, took me less than 2 mins and had no idea what i was doing :retard:
cant really see anybody wanting to buy one of them pal but cheers for heads up
No me nither, but i only got mine cos i needed a car that weekend.... you only realise how rubbish they are once you have one :lol:
It may be an old wives tale, but coating the door seals in vaseline stops them sticking to doors (apparently).
it works, but can apparently eat away at the rubber
My locks used freeze up everytime.
As Bongle said, Wait until your locks are dry(ish) and then Spray WD40 in or some other Oil.
It wont freeze (Unless its seeeriously cold), and it'll just pop open.
My boot used to always open though, so i could climb through the back and unlock the doors =]
Pouring hot water on the locks just puts more water into it, which then freezes the next day..
Still need to get some silicone grease around my door and boot seals to stop em freezing to the doors/boot, keep forgetting lol!
As for my locks I just get a bit of deicer on a tissue and wipe it round the lock, works for me at least.
All but one of my doors froze when it was -17c here the other day. Had to crawl into the car :(
vaseline on your key and put it in the lock the night before ... wont freeze in the morning :)
Chris
Car won't be there either.
Oh, wait, you're supposed to take it out - my bad :oops:
will WD40 not freeze too as its water based?? Could be wrong tho
Kuszpit :)
Penetrating oils are not water based,mate.. :lol:
GT85 is unusual because it contains Teflon.
yeah, get a can of spray silicon lube, spray all your seals etc, works fine, & spray some wd40 in locks, barrels etc, iv had no problems x
was thinking about this the other day...who relies on solenoids for getting into their car??
be interested to see how you guys are getting on...mine did get stuck a few weeks ago on my boot because of the cold weather but now fine...
wouldnt trust a popper to open my doors tho..
sounds like alot of people hve been experiment with vaseline an diffrent types of lube, but besides that I've never had any problems in the mornings
Warm water didn't work for me this morning so heated my key up a bit on a flame then gave it a wiggle in the lock and it worked :-o
recently I've found I've had more of a problem with my windscreen freezing...on the inside lol.
de ice the outside and then have to scrape the inside lol.
The mk4 is a bastard for the doors being frozen shut. Took 10mins to get in this morning :( looks dodgy when I get to work and I have to climb over to the passenger side to get out!!
Tried the G40 - key in lock, broke snow off handle and voilà - straight in ;)
piss on your doors :D
Jbird where abouts in chesterfield are you from?
Ash
I don't have door locks anymore, and the door seals aren't that exposed on a mk4 so they don't tend to stick to the doors in freezing temperatures. (Used to be a real bugger when I had a mk2 golf). However if your locks are frozen and you are still at home, a quick blast with the hairdryer usually does the trick.
Ye had it the other night, sprayed de-icer into it and now lubed it a bit.
Even worse yesterday that i couldn't get into reverse as the gear shift had frozen :lol:
Good load of WD down under the gaitor sorts that out!
I WD40'd my locks before the cold weather and not had a problem! had a slight issue with the seals frozen but eased it open gently and was easy enough :) i heat the key with a lighter as do some others if i cant get in, works a treat!
My door poppers are getting on fine. None of this frozen lock milarky. Push the button on my fob, door swings open and I'm in :-D although i hope the door catch doesnt freeze otherwise i would be absolutley buggered, as there would be now way to get heat to it. Cross that bridge when it gets to it tho.
When i found out we had that kind of weather on its way i sprayed a tiny bit of wd40 in the locks worked a treat been able to get in it every morning with ease
WD40 works for me...
Wont freeze as its Naptha based (petroleum)
This happens to my 6n2 all the damned time. Front two doors wont open, the back two will. All you gotta do is spray some de-icer into the locks, and it opens instantly. Halfords sell these little lock de-icer for just over a pound. * cough ~ shameless promotion ~ cough * :roll:
