door cards
How do i remove the rear doorcards in a mk3. Did the front easy but can only see one screw on the rear ones and after taking it out they still seem just as solidly fitted. Don't want to damage them as will be re-using them when done up
  • Views 826
fuk me! it aint hard! use your brain n ul have um out in 30 seconds!!!!!!!
One screw near the front seatbelt mount, possibly some along the bottom to the side of the seats. It'll be wedged in under the window seal at the top. Should be pretty obvious though if you look around all edges of it.
thought it would be simple, just didn't wanna damage it my yankin it off. Had already got the screw out but still felt just as solid as with screw in. Thought perhaps you had to slide it to one side or something first. Would rather be careful and get it done properly than just rip them out and damage them.
