9N Question
Hi there,
I'm Greig, I used to be on clublupo, but have now sold the car and am looking for a polo.
Going to be looking at a polo 9N tomorrow, and wandered if there was anything i should be looking out for. Car is a 53 plate with 77k.
Any info would be greatly appreciated.
Cheers,
Greig.
Picture of the lupo incase you were interested:
  • Views 773
depends what model it is, but id just do your usual checks, i.e crash damage,check panel gaps etc oil leaks ,smoke etc, have a good drive of the car, listen for any knocks or rumbles,as they can have front suspension issues,mostly with the arb links shockers can be weak too..listen for wheel bearing rumbles also.If its a 1.2 your looking at they feel a bit throbby anyway due to them being a 3 cylinder, however, this should only be slight to moderate,.oh, its always good to have history as well,I've also saw a 9n that has started to show rust bubbles at the leading edge of the rear arches,but i will state-only ONE!
hope this helps :-)
Edited by BLUG
Thanks for your reply.
Went and bought it today - its a 1.4 se with fsh and no problems on the face of things.
Will have pics up tomorrow!
