Removing Mk3 wings
Can anyone help with some tips for removing the wings on a Mk3?
I've whipped the inner arch trim out, disconnected the side repeater, removed the aerial, taken off the front bumper (having had to drill out all but one of the bolts) and made a start on the passenger wing. The little Phillips-head screw at the front was a damn pain – broke a screwdriver and no matter how much penetrating oil, heat or leverage was applied it simply would not shift...so had to drill that out too.
Let must just check I got all the 10mm bolts that hold the wing on... 4 along the top edge, one underneath the bumper at the front, one on the outer sill buried in underseal and I think there’s a further two buried in underseal inside the arch on the door-side? The thing is still pretty well stuck. I think it’s a case of knifing some more underseal...but if anyone has any experiences/tips to share they’d be very welcome! Cheers
  • Views 942
yes there are some underneath the sealant inside the wing near the front of the door, this sealant will also hold the wing on even when those bolts are removed so you will have to cut/scrap it away.
IIRC there's four up there. I find if I put a 6-sided socket on with an extension bar, and tap the bar a few times with a hammer, it usually works for getting through the sealant sufficiently.
I've given up on the damn thing. Was going to take it off to repair rust, but the sealant man at the factory went overboard (blocking up the bottom which caused the rot on the first place) and the wing is not going anywhere without getting badly bent in the process. Am just going to do my best with it on the car :?: Thanks for the tips though chaps!
Edited by cheys03
