pioneer audio amp and sub
hello everyone iam selling my amp and my carbon fibre sub
•Slim, compact 10" (25cm)shallow-mount subwoofer
•Maximum output power 1.000 Watt
•Nominal output power 250 Watt
•Frequency response 20 - 1000 Hz
•Sensitivity (1W/1m) 87 dB
•Woofer size (cm) 25 cm
•Woofer material Interlaced Glass/Carbon Fibre reinforced IMPP™ upper cone
•Recommended sealed enclosure (Litres) 17 litres
£65
•MONO BASS AMPLIFIER
•Specifications GM-D8400M
•Maximum Output Power 1 x 600W (4Ω) or 1 x 1200W (2Ω)
•RMS Power: 1 x 300W (20Hz - 240Hz/4Ω)
•RMS Power: 1 x 600W (50Hz / 2Ω)
•Frequency response 10 - 240 Hz
•Distortion < 0.3 %
•S/N ratio > 80 dB
•Bass Boost 50Hz, 0/6/12 dB
•LPF 40 - 240 Hz (-12 dB/oct)
•MOSFET output section
•RCA Input terminals
•Speaker Terminals: Block-type
•Input level control RCA (200mV - 6.5V)
•SP (0.8V - 26V)
•Switchable, LR independent
•Max. current consumption (A/4Ω) 27 A
•Chassis size (W x H x D) 290 x 56 x 200 mm
•Unit weight 3.2 kg
£120
also if u want them in a lupo i will sell the boot build aswell
cheers matt
Edited by vpolo
  • Views 441
open to offers
