6n2 Front Light removal
My front lights have dust on the inside of them and I'm planning on removing them and cleaning, I know you have to remove the front bumper to remove them and I've seen a post on here before but can't find it, anyone help?
Also how easy is it to open up the lights once removed?
cheers :)
i have removed the headlights on my car to replace with new ones, i check with a VAG dealer to see if i could get the lens only and the answer was no unfortunately, the only way to clean the inside is to take the lens off clean the glue/sylicone and get sum new sylicone to glue back together. i nearly got the lens off but i would suggest, if you are a technician to use compressed air to clean the lens.
to remove your front bumper,
there are around 16 or so allen key screws, they are located :
In your wheel arches, mudflaps
Under your grille
And 1 hidden screw under each of your indercators.
Undo all of these and bingo!
Hose pipe in the lights should do perfect, then use a hair dryer or let them self dry
:thumbsup:
