Changing Front Headlights 6n
help!
Cant quite get the headlight out. Taken the top 3 bolts out and the unit is wobbling, but wont quite come out. What am i doing wrong, or missed?
  • Replies 8
  • Views 1.3k
have you took the one under the headlight ?
take the bumper off, it will all become clear.
jus take you grill off mate and there another bolt under the light which can be got at with the grill of thths how i got mine out
If you take the front bumper of, there's one torx screw under there.
It would make it REALLY easy if you took the bumper off but thats work that you dont need. Just remove the indicators, then under them there is the bolt either side for you grille. Remove them and take your grille off. then you will see a half moon shaped cut out in the bumper under the headlight. in there is a 25 torx screw. Undo this bolt (it is attatched in there, so when you loosen off it wont come out, if you understand what i mean) once you have done this just give it a little wobble and it will come off. The torx bit under the healight can be a bit stiff, and hard to locate but thats why the cut out is there to prevent you from having to remove the bumper :)
Kuszpit :)
I remember when on my old polo, i changed the headlights but didnt clock there was a torx under the light, and after getting really annoyed it wasnt coming out, i ended up snapping the clip :( and leaving the screw in there wen puttin the new lamps in. Fun day :D BTW make sure you screw the grille in before the indicators, not much fun the other way around :D
Good luck matey :p
I take the bumper off as it's a ten minute job if that and it's defo easier
Got the screw out without taking bumper off.
Thanks for the help everyone.
Got my powerlooks fitted :D
