Waterleak in passengers side
as described in the title it seems i have a waterleak in the passengers footwell.
but i dont know whats causing it does anybody know any causes of this?
thanks for looking
  • Views 1.2k
thanks for looking
mate check your coolant might be your heater matrix
check your drains arent blocked underneath the plastic panels under the windscreen wipers.
if these are blocked and get full of water it will leak in through the passenger foot well
thanks for the reply guys, will be doing this tomorrow then :thumbsup:
From this thread: http://www.tigerstyle.co.uk/phpBB3/viewtop...c46df256d124fc9 over at uk-polos:
Dan 6N: "Check the scuttle. In the scuttle area at the top of your engine bay (where the pollen filter is) there are vents into the car. If the scuttle gets filled with water the water will run through the car into the car. To get rid of the water in the scuttle, there should be holes at each end which channels the water down by the wheel arch and away from the car. In your case these holes are probably blocked. Unblock them and hopefully your problem will be solved!"
thanks VWKing that sounds probable will be trying that aswell
just another thing for you to check mate,i get water coming up over my door seal at the bottom for some reason,
and then it runs over the interior trim and into the passenger footwell.
maybe worth checkin this next time you wash it.mine had 2 new door rubbers and still leaks :-(
hope this maybe of some use.
sean its nothing to do with your door seals its the plastic liner behind door panel thats letting the water into car
